94 Talon M/t Flywheel Eclipse Flywheel
ShawnC
Oct 3, 2007
Missoula, Montana
Totally new to this so forgive me if this is a dumb question. I have a 94 eagle talon turbo
fwd 5 spd. Motor was blown so I bought a used motor from a local yard out of a 93 mitsu
eclipse. All went fine until I got to the flywheel. The Talon flywheel will not bolt on to the Eclipse crank. Do I need the flywheel off of the Eclipse?
Did the Eclipse have an automatic transmission?
What do you mean by not fitting?
Is there a different number of bolts from one crank to the other?
Unless the eclipse was a non-turbo or something weird it should fit just fine. We really need some info as to "why" it won't fit. Maybe some info on the two cars would help. Is yours awd or fwd? What about the Eclipse?
If the motor came from a car with an auto trans there is a ring in the center of the crank that needs to be removed. If one of the motors is 6 bolt and one is 7 bolt the flywheel will not be interchangeable either. If the motor is from a Talon / Eclipse or AWD/FWD shouldnt matter. 6 bolt/7 bolt or AT/MT dose matter.
How do you remove that ring? I've been struggling with this for about 4 hours. I've been converting my 96 gst with f4a33 to a manual. everything else was easy, now I'm down to the flywheel not bolting on because of that ring..
  • For sale 2g 2G DSM ECU
    Came off a 1997 GST M/T. Stock ECU
    • Stizzydrew
  • For sale 1g 90-91 Talon pass taillight.
    Pass taillight for 90-91 Talon. Good condition. No breaks or cracks. Will buff up nice...
  • For sale 2g 2G Manual Window Assemblies, Door Panels, & Hardware
    2G Manual Window Assemblies, Door Panels, & Hardware $250 + shipping and paypal feesYou must...
  • For sale 2g 2GB Talon Wing ( 3rd brake light included )
    2GB Talon Wing $90* pick up only in 08096 NJ * 3rd brake light includedYou must be...
  • For sale 2g 2GB Talon Front Bumper
    2GB Talon Front Bumper $200* pick up only in 08096 NJ * tear on the bottom side, picturedYou...
