94 Eagle Talon
shaw
Jan 23, 2008
Altoona, Pennsylvania
I have a Eagle Talon frame an body.
The specs for the car is as followed.
Dohc 14 2.0L
135 hp
5 speed
This is the specs for the stop car.
:thumb:What if I put a a 4G63T JDM Engine in it.:thumb:
Would it Fit?
Would the Frame,Body,Drivetrain handle it?
Please reply
As long as you put a fwd tanny. Everything will fit. Also if you buy a jdm motor there are some modding your going to have to do to the motor. Just search the formus all info is there.
im not sure about the 1st gen car but with a 2nd gen turbo car (95-99) the tranny is on the left side of the motor and on a non turbo the tranny is on the right so you have have to custom make mounts.
Before you get on someones case about searching you should realize what you are doing. The thread you linked to is about putting a 4g63 into a non turbo 420a 2g which is completely diferent than what the OP is asking about. :nono:
To the OP you will want to read these two tech articles. There is tons of information about what you want to do in these threads. Good luck with the build. :thumb:
http://www.dsmtuners.com/forums/art...r/5986-4g63-nt-engine-how-make-turbo-kit.html
http://www.dsmtuners.com/forums/art...48231-installing-turbo-4g63-into-nt-4g63.html
All 1g's have their tranny on the right side (passenger) and the rest of the motor is on the left side. Some 1g's came with a 4g63 N/T, so its basically a direct swap if your putting in a 4g63T in it. All you have to worry about is the harness.
