93 tsi ecu into 91 tsi
if they are both 2.o turbo motors and awd cars the motors will interchange just fine but if one is a awd and the other is fwd than u will have to change the starter plate and flywheel and the mount brakets on the lower part of the engine
both are awd.....but the 93 is an automatic and the 91 is a stick.....i just want the 93 to be my car to get to work..its blue smoking and burning oil ..so i bought the 91 to swap engines
I would do all that before pulling the other engine. One Quick way to tell if the turbo is to pull the inter cooler piping and see if the inside is coated in oil. If so definatly the turbo.
Try just turning the key on. If the stock boost gauge goes to the zero mark and the check engine light comes on the ecu is working.
91-94 ecus (turbo) dont need any modification to them. I know an automatic turbo car will come with a smaller turbo and injectors so Im pretty sure that will be in the ecu.
90 ecu turbo will work but you have to swap a couple of pins around for it to work right.
thats what it looks like
ill add that to the possibilitys..ill see if i can take off the part from the running one and see if itll fit in the 91
Try the ECU thing first, then check all fuses under the dash and hood. then try that. then coil pack.
