1G 93 talon awd auto no overdrive .
1SIC1Gb
353
73
Jun 25, 2012
Houston, Texas
So my 93 awd w4a33 trans doesn't have overdrive. It's not the typical slipping when in od, this just doesn't even try. Has every other gear . It just stays in 3rd no matter if the OD switch is on or off. Switch is showing off or on correctly on the cluster . Just installed new end clutches just in case but no difference .
What wires do I need to be checking . I looked at a diagram and I cant figure it out. I see the 4 green wires coming off the cover where the end clutches reside but couldn't find them on the diagram
Thanks
Tried to pull the codes but I need an analog multimeter. Would anyone happen to know which wires should have power/ground when od swith is turned on?
It has a 2 plug tcu. I can't seem to find a good wiring diagram that shows the overdrive switch . Wanted to check the connection to the tcu.
So I tan a straight wire from the red/ white on the ecm and ran it to the red/white on the shifter of button . Now it has od , oddly enough the OD works when the OD switch is off . Still better than before of coarse since it has od.
