- Thread starter
- #76
Stapl3
DSM Wiseman
- 2,294
- 1,015
- Oct 27, 2004
MI,
Michigan
Added my 8an return which only required modifying the pump bracket a little.
I determined the return fitting and 6an male fitting would interfere with each other, so I used a 30* washer.
I will have to pressure test this before using. Aside of cutting the pick-up tube to length, some wiring, putting in a Walbro pump, this is about done. I am currently waiting on about a billion dollars of fittings, check valves, filter, merge, etc.
