93 Laser Timing Adjustment help?
StandBackImaPro
51
Aug 15, 2005
Brick, New Jersey
Ok I have a 93 Laser, N/T, it has Comp Racing cams, The Idle is messed up, I asked a mechanic and he said id have to turn the cam pulleys back 1 tooth,
It will idle low almost about to stall,
When u get into second gear and try to accelerate the car backfires and jerks
I tried adjusting the distributor, that helped a little but then it did it again,
the car also has idle surges, it can idle good for a second, but if u give it a little gas it will shoot up to 4 grand, and hold there for a second then go down
they are non adjustable pulleys BTW
So can someone help me please
StandBackImaPro said:
Ok I have a 93 Laser, N/T.
Your profile looks like it's for a V8, so which version of the N/T do you have here since the 2.0L 4G63 doesn't have a distributor and the 1.8L 4G37 does.
It makes a big difference.
Steve
Its the 2.0, I Guess its not a distributor than, Whats the thing on the left side of the head then? Thats what i was moving
That would be your cam sensor. You can loosen the bolts and adjust the cam sensor to see if that will help the stalling issue.:laser:
When you adjust the cam sensor. You need to ground the timing adjustment terminal pin. Then adjust the timing to 5* BTDC by turning the cam sensor and when the timing adjustment pin is not grounded I believe the timing should be 8*. To do all this ya need a jumper wire with aligator clips, timing light, and a 12mm socket. And of course clip the timing light to Cylinder #1.
