93 Eagle Summit 2.4l r12 to r134a conversion
KEagleSummit
Aug 15, 2025
Waterford, Michigan
So I’ve been doing research on the r12 to r134a conversion kit for the 93 Eagle Summit. I have not been able to find much regarding it. I figured I would post on here to maybe find some good information.
PAG oil rather than old fashioned mineral oil. Make sure the system is thoroughly flushed to remove any contamination. You may or may not notice the air being a little warmer than before, assuming you experienced the R12. It will function great if you put in the effort. New dryer and proper fittings does some work. Let us know what happens! :)
It’s 80% of the capacity of R12 for the conversion.
You should pull a vacuum.
It shouldn’t be that much to do a evac & recharge with a proper machine at a shop.
