93-94 big brakes
blueman803
216
Nov 3, 2003
chapin, South Carolina
Would it be possible to go to autozone and get remanufactured calipers and bolt them in? Would I still need to find shims or any other component?
Your title says "big" but your question is unclear. What are you trying to do?
You need the calipers, the mounting brackets and matching rotors to make the dual piston brakes work. Most Autoparts stores don't include the brackets with their remanufactured calipers based on what I've seen over the years and finding just the brackets after isn't easy.
Steve
bought mine with brackets from mitsu graveyard. Advice: don't buy the brakes from them unless you have access to a torch. I had to bring the calipers into auto school to heat them up so the damn caliper slides would come out. But, I got them on and they work great now!
what exactly are the mounting brackets? any pictures or maybe a little description
From the "Big Brake" VFAQ. http://www.vfaq.com/mods/BigBrakesInstall.html
The red piece is the bracket. It bolts to the knuckle and the caliper attaches to it via the guide and lock pins. It's different from the bracket used on the single piston calipers.
Steve
