92 galant transmission?
toppertopper
444
May 14, 2009
edmonton, AB, Canada
I can pick up a 92 galant awd transmission for a decent price , while i fix/play will mine..Will be going into a 93 awd tsi
My question is do they bolt right up ? What do i need to change or swap ? Can i use my clutch or do i need another clutch & fly wheel ?
Haven't found out if the 92 galant transmission is from a turbo'd car or not ..Will that matter?
For all the research you're doing you could've had it fixed and back in the car already. You need a w5m33 transmission. If it's from a non turbo gsx galant it will be a w5m31 and is not the right transmission. Bigger pita if I recall. Galant transmission will be a bolt up for you. Gear ratios are different for first, all else is the same.
