91 Tranny on a 90 car (AWD)
laserspeeddemon
6,716
66
Jul 26, 2002
Fredericksburg, Virginia
I don't want to make this long.
I have a 1990 Eagle Talon TSi AWD. A mehanic took it for a joy ride and forgot to put tranny fluid in it... bye bye tranny.
I found a 1991 Eclipse GSX motor/tranny WITH T-case. I know the T-case will fit to my driveshaft. I know the Tranny will bolt to my motor. That leaves the axles. I'm only paying 300 for it. I might take the risk if I don't get it answer by Tuesday
heres my question:
Will 90 axles go into a 91 tranny. And is there anything else I'm missing for this swap.
I just put a 91 in my 90 and I needed the shift rod bracket as they are a little different it was 20 bux at a junkyard. The trans should come with the shift cable bracket so you wont need one of those. I however did have set of 91 cables that I put in just in case. But my 90 shift rod assembly definately didnt work.
