91 talon tsi surge idle
4g63t_colector
Jul 22, 2015
Hayden, Idaho
What could be my problems with surge idle, it surge idles only when stationary or when not in gear, and does anyone know where I can get oem master cylinder clutch and oem slave cylinder?
By eliminating the extra air that's causing the engine to idle higher than the factory limit for when the throttle is closed. You'll note that the ECU won't cut the fuel off (capping the rpm) if it thinks the throttle is open (by disconnecting the IPS).
Since I don't know anything about your car I can't be more specific.
Have you tried JNZ or STM for the master and slave cylinders. They sell OEM parts.
