1G 91 ABS leaks. Can I rebuild?
chuckd
91
Sep 29, 2009
roseville, Michigan
hey guys.. i have a 91 awd auto with abs and there is a small pinhole leak on one of the vertical bars.. i am not sure if i can take it apart or not. and if i do is there some o rings i can replace?
if not. i guess i will look into abs delete.. but wont i have to run new rear lines?
mine leaked too. i didn't feel like even trying to fix it. all you need is the non-abs proportioning valve, front brake lines, and the lines that will go from the master cylinder to the proportioning valve (as opposed to from the mc to the abs).
what about the back brake lines? hmm how hard is this to do with the motor in (in the abs car) the motor is out of the non abs donor
nothing needs to be done to the rear brake lines, they connect to the proportioning valve on both abs and non-abs. when i did mine i just cut the lines to get them out. putting them in was easier than trying to remove uncut lines for some reason, probably because the non-abs lines don't go mc -> abs -> prop valve -> wheels and just mc -> prop valve -> wheels.
