1G 90 Talon Fuel Hanger
Badge023
76
73
Nov 9, 2025
Ewing, New Jersey
So, I picked this car up as a parts car. I pulled the fuel pump and hanger out and this is what I have. I found the pump is from a 3KGT. The couple of questions I have is; is the pump ok running a stock 4G63T and also, was this some type of kit for the fuel hanger? The fuel hose is high psi rubber (which is starting to split at the fittings) with -AN fittings that mate to a metric flared line on the underside of the car about where the rear of the driver's door jam is. Planned on using it in my 93 Laser since that hanger is all messed up.
The Denso 195130-0810 190 l/h pump is a old school upgrade for mild injector upgrades. I have one in my Eclipse. In the 3000GT VR4 (Stealth RT/TT) they ran it with a two stage power switch so it wouldn't overrun the OEM FPR but I haven't noticed any issue on my car. The more typical Walbro 255 and larger upgrade pumps tend to overrun the FPR and require an adjustable FPR to manage the flow rate.
I'm not sure what the questions is about the hose. I'd just make a new one and if you can't find new fittings, slit the hose and recover the old ones.
