90 talon.
dsmman91
192
May 23, 2011
Tricites, Washington
I have a few questions about the difference between 90 and 91 dsm, i might be abe to pick up a 90 awd tsi for a good deal and was wondering what will i need to change to make it a 91. I heard the 91 and up dsm are better why is that?
any help would be awesome.
Never heard of a 91 being better just ecu wires need to be changed with the 90 ecu. Cant think of any differences between those two cars.
throttle bodies, shifter base, shifter cables, shift bracket on tranny, oil pump gears, output shaft spline count, thats all I can think of that differ from 90 and the 91 ups
There are differences with the transmission itself if I remember right. I know English Racing had to use parts from a 93 to rebuild mine since 90 parts aren't made at all.
But yeah, pretty similar or stuff that can be easily swapped.
The wiring harness is different both under the hood and under dash so if you want to swap it all the way to a 91 you will need both harnesses and a 91-94 throttle body and a cas (cam angle sensor) ecu coil pack and the power ignitor the rest you just plug and play
  • For sale 4G63 Groden alum rods. Set of 4 with ACL bearings
    Groden aluminum rods. Set of four. 22mm small end. With ACL race rod bearings. Locating...
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
