90 instrument cluster into a 91
packinkimber45
378
3
May 26, 2006
Boise, Idaho
Hello members, when we first picked up the talon I noticed that my gauge cluster oil pressure gauge and water temp acts funny so I switched out my 91 cluster for a 90 cluster. Come to find out they are not compatible. Rpms were not working at all. After doing some research 90 vs 91-94 clusters are incompatible. My question is since I tried the 90 cluster in my 91, could that have damaged anything? Can I just put in my gauge cluster out of my 94 eclipse gs (non turbo) into my 91 talon tsi? I already have an autometer boost gauge so not having the factory boost gauge is no issue. Thanks.
Swap just the tachometer from the 91 cluster into your 90 cluster and the tach should work. You don't even have to remove the gauge needles or faces.
Everything worked but the tach after you swapped to the 90 right?
This is a 91 n/t cluster over a 90 turbo cluster, you can follw the traces and see that they are very similar.
Here is a 90 turbo tach next to a 91 n/t tach, you can see the differences in the wiring and electronics.
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted 1g WTB: 4 Bolt Axle Cups.
    Looking for a set if 4 bolt axle cups for a 1g. Located in Canada.
    • blaster1812
  • For sale 2g 2G Manual Shifter Cables ( including NEW bronze bushings )
    2G Manual Shifter Cables $90 + shipping & paypal fees* I will be including NEW bronze bushings...
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
