90 awd in 95awd?????
are you talking about the rear diff? if so i don't belive it will fit. the axels in the 2G are a diffrent lenght then the axels from a 1G.
what if i use the axles from a 90, and use mine to, and change the one end of the 90s to the same spline as mine, they will be the same length, and they will have the same spline, and so far everything i have looked up says that they have the same ratio, and the rear end i have is a 4 bolt just like the old one of mine
the internials to the 90 diff and the 95 diff are excalty the same, right down to the serial numbers on the parts, they can be taken out of one, and put into another, and parts can even be put together, but when using a 90 transfer case in a 95 u have to custom make mounts since the bolt holes done line up. But it is possible to rebuild a rearend using a workable 90 diff and a broken 95 rearend :thumb:
