We're on Boost
- 3,143
- 1,547
- Aug 25, 2007
Seattle area,
Washington
Yep 9:1 is OK. Mine is nominally 9:1. People had pretty much figured out how to make ~500 awhp on pump gas by 2007 and I suppose some were earlier. But the best documentation of it that is still online that I know of is the same thread in EvoM that gave me the direction I needed for how to do my car. I wanted ~500 awhp potential on pump gas because E85 stations were disappearing rapidly in my area.but 9:1 is fine.
Anyway, people started using larger turbine wheels (for example GT35 instead of GT30) and newer tech compressor wheels, better engine management, and all the other stuff guys above have mentioned.
So read that thread in EvoM here: New record for pump gas, set with the HTA35r
Actually, read post #1, then if you want to skip the dozens of fanboy posts, go to post #15, then #25, then #62 which is the best post in there for how and why, and #62 is where Buschur says the compression ratio was approx 9:1.
BTW it came out later that the turbine housing on this car was only a .63 a/r so they were actually giving away a little top end for some gain at lower revs with that.
The charts that were originally posted in that thread are all lost now but I have some of them saved, if anybody wants to see them.
That Buschur build was obviously an expensive build.
If you want a lower cost build and some amount of safety, keep it down to 400 hp!
For me with a high cost build, I keep my ethanol percent around 40 - 55% for most of the year and boost at about 27 psi. It still makes 550 awhp set like that, and that is my idea of good safety.
it’s very forgiving
