9.08 @160mph video...
yellowrs said:
Can you explain a little more about the tranny you guys are running, like stock gears ect.? I assume that its not just your bacis rebuild ROFL .
Alex's white Laser and my Talon both run our race build package. The only difference is I now run dbl syncro 3rd and 4th as well as our viscous eliminator. These options are not on our site but are offered to customers looking for a full build up.
What's the A/R on the turbine housing you are using? Is it divided or undivided?
Wow! Thats damn fast. What boost level you running? Could you generalize what you pulled out to bring it down to 2650lbs with you in it? Did you go on a diet too ;)
I weigh about 185, to bring it down to this weight cost equal amounts of time and money. All the basics I don't need to mention like sound deadening out, power steering, bumpers... more advanced weight reduction came from re-doing the entire cars wiring, car still has lights and blinkers using factory switches, this shaved about 15-20lbs. Front Brakeman brakes shaved some weight, alum. driveshaft, non steel belted tires, and just over all eliminating everything that is not needed in and around the car.
Congratulation for the car, I upgrade my 1992 AWD but I drive it every day so I can't do the same but maybe I can arrive around 2800-2900lb and for me is good enogh.
