8/90 Ecu!
kwaliph
80
Sep 7, 2005
Yuba City, California
I have a 91 GS-T and so I bought a chip for my ECU. So i removed the ECU and opened it up to see no place to solder the EPROM craddle. Sure enough, my doorjam reveals it's an 8/90 production year :notgood: .
My question is; Is it possible to swap an ECU from an earlier PY (I.E. Say a 2/90 or any other 90 equiped with an EPROM) instead of replacing the ECU from a 91+ GS-T along with the other headaches required (I.E. Coil Pack, Coil Transistor, Tach or Instrument Cluster)?
Have you checked the car to see what type of power transistor module you currently have?
You car was made in 8/90 but it should still be a '91 model year car with the '91 coil pack and PTM. If that's true and nobody swapped a '90 engine into the car it should use a '91+ ECU.
What was the part number from the ECU you pulled?
Steve
HOORAY!!! Your were right Steve. I didn't checkup on the ECU number but i do have the triangular coilpack harness (91+) :thumb: :thumb: . For any reason, here's the ECU number currently in the car: MD166260
Turns out it was changed about 6 months ago due to ECU failure (leaky capacitors).
The only thing that stumped me is, I thought it was neccessary to swap the coilpack and transistorpack because they use 2 different tach signals, how is my tach able to operate with a 90 ECU?
That's a 91-92 FWD ECU for a Federal turbo car built between 6/1990 and 6/1992. Exactly what I would expect to find in your car along with the 91+ coils, PTM, tach and the rest of the stuff they used on the '91 model year cars.
Steve
