Please Support Rix Racing
Please Support ExtremePSI
90 ecu question
EvMan2345
Jan 30, 2003
Stamford_CT
will a 90 turbo FWD ecu work in a 90 turbo AWD? the ecu is out of a manual and the car is manual. I need to know ASAP - Thanks, Evan
I can not give you an absolute definate answer, but mine is yes. The cars are the same year and the same engine. The only thing that differs between them is the transmission. Because the engine is the same it works off of the same fuel maps, therfore the ecu is the same.
yes!
im running a 90 fwd ecu in my awd 90 till i get my caps to fix in my awd ecu.the only thing i read was the awd does not have a speed limiter and the fwd does other than this it has been running fine!
