7 bolt jdm help
Fill in your profile we cant help you if we dont know what you have.
what are your goals?
why are you replacing motor?
if its a complete long block then no it wont work just strait up. you have different evap/vacuum set up different tps set up. just get a 2g all your stuff will swap over but you can find something alot cheaper locally. or just rebuild your engine. places like that are a waste of money and time cause at the end of the day you still end up with stock power and stock set up.
