engine swap 7 bolt jdm HELP!!!
jrcramer1
Jan 20, 2008
rochester, New York
I dont know if this has been posted beofor but i need to get some answers to see if im in way over my head. i just bought a 95 talon (auto) but i am switching it to manual. i bought with no motor or tranny. i bought the jdm 7 bolt for it. i have heard people not having problems but then i talked to a few guys and they had issues lining things up, like the axels. should my axles line up to the tranny and should i run in to any problems befor i have a regular shop do the motor install? i would do the install my self but i bought the car near my mom and i wanted to get it running before i shipped it to me. thanks, any help would be great......
you shouldnt have any problems but if you do, a set of axles from a manual car should fix the problem.
please let us know how this turns out and good luck
are you talking about the carrier bearing on an AWD? If you are a little more specific in your problem you will be more likely to get accurate and timely responses. It sounds to me that is what you are asking about, if so, then I have no answers. if oyu are worried about axles and the JDM engine, the axles dont go into the engine, no problem there. if you are worried about the auto to manual swap then tsi8820 had the right Idea. on a side note the auto and manual use a different transfer case (just food for thought).
