7 bolt crank swap (2g into 1g)
1WheelDrive
May 11, 2004
Calgary,
I have got a 7 bolt 1g motor that got right screwed up because of a certain mechanic who installed standard sized main bearings into a crank ground .25over. Now since I need a new crank, the 2g cranks seem to be more redily available and I was wondering if the a 2g crank would fit into a 1g 7 bolt with no issues. Thanks in advance.
Hey i know this isnt exactly on topic but you may want to look into stroking your motor since you have to get a new crank anyways. i mean you will have to get pistons too but hey might as well go all out since your already going to be in there.
All 7-bolt 4g63 motors use the same crank MD346024
-Russ
