dberry
- 32
- 0
- Apr 9, 2012
Clarksville,
Tennessee
I'm currently running a 16g Turbo with 650 CC injectors and stock internals, I am using a greddy boost controller with an Apexi safc2 to adjust fuel ratios, a 2g maf, with a greddy bof, I'm buying a hks ball bearing gt35 Turbo to use with the headder I have for an external wastegate and I'm about to buy h-beam rods and some pistons that will up my compression ratio to about 8.5-1,
With this kind of compression ratio jump I know ill get more HP but I also know ill need to dump more fuel because the uped compression will burn hotter, keep in mind my valves are stock and I don't know if they will stretch with that kind of heat, would it be a good idea to get sodium filled valves? And should I get larger injectors? I have a few ideas about heaving 8 injectors on a custom intake that I could Fab up but like I said my goal is to hit 400 fwd HP and be reliable for a daily driver.
I'm not new to building NA motors but I'm still working on learning
more about Turbo motors
All suggestions are welcome
more about Turbo motorsAll suggestions are welcome
. Of course, if you go with the 2G (or any MAF placed before BOV) you must recirculate the BOV -don't vent to atmosphere.
The EVO heads generally have a better valvetrain all around but unless you get a killer deal -just go full blown aftermarket.
