2G 6500 idle
420a non-turbo
Jun 13, 2017
Columbus, Ohio
I've got 97 Mitsubishi eclipse RS 2.0 non turbo dohc 420a engine block... On my way home my car reved to about 4500 rpms while in first but it was as if the gear wasn't engaged and it wouldn't move. It's gotten worse now. When I start my car it jumps to 4000 rpms and then rests at 6500. Idk if the gears catch because I'm pretty sure trying to shift into first at 6500 isn't a smart idea.... But I've checked my throttle body sensor, my IAC, all my vacuum lines, my air filter... Idk what else to do... What's going on?
I believe so I think there's an I'm intake manifold bolt under my car..... my engine shakes violently.. could it be the cause of my bolts being loose. Because all of my valve cover bolts were loose... And at one point it knocked off my oil cap and my air filter, and I recently had to replace my clutch and flywheel because my bolts came out...Could it be a result in a bad engine mount
