6 bolt to a 2g A/T tranny
CrazyGSX
168
5
Feb 13, 2004
Waterford, ON, Canada
would anyone know if a 2g a/t Tranny has the same splines on the input
shaft as a 1g tranny? or can you get a 6 bolt flex plate to mach up
with a 2g Torque Converter?
I used a 90 at N/T flex plate and had the tq modded ( check my gallery for pics) . Also you have to open up the piolet bushing for the crank .
what was modded on your tc? and did you get a shop to do it or did you mod the tc yourself.
2G tcs have 4 mounting pads for the flex plate the 1g at only has 3 that is what I had modded . It as done by a shop here in Mich that rebuilds tcs .
not all 1g flex plates have 3 mounting holes. i have a 92 gsx auto and mine has 4. i put a 2g tranny and converter in my 1g. all i did is egg the holes out to match the 2g converter. i also had to put the converter in a lathe and take some material off the back of the converter to make it work. you can't use a 1g converter in a 2g tranny because the 1g is not a lockup and the 2g is. you would have to get a custom converter made.
  • Wanted 2g 2g Hood latch support
    On the hunt for the support that holds the hood latch assembly.
    • jesse12345
  • For sale 4G63 Hallman ES Boost Controller
    Boost controller
    • jpturbotalon
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
