6 bolt swap
evil tsi
241
Feb 26, 2011
findlay, Ohio
its a pretty basic question but i couldnt find the answer after searching. i changed the firing order in my 96 using a green top cas. i switched the firing order from 4123 to 3214, do i need to swap pins out in the ecu harness for the injector triggers too? or does it make a difference?
That was the most ridiculous response I've ever seen, if you have no real knowledge don't respond,the so call push of a button is called inverting cam sensor signal. Im using a green top cas and i don't need anything to tune with, im breaking in the motor with stock turbo, stock boost and stock injectors. The question was do I need to swap injector trigger wires even though I swapped firing order?
not sure why he is talking about the black top, but yes since you are running the 1g green cas you need to swap the injector pins at the ecu so they fire with the plugs. if you are using link you can just got to misc tab and check the 95-96 inverted signal and it should fix everything, but if not just switch the plugs and injectors.
here is the magnus write up magnusmotorsports.com/wp-content/uploads/2010/02/1gina2g.pdfSimilar
rre has one also but they are pretty much the same.
not a problem, simple answer for a simple question LOL. just follow that guide you just have to switch 4 wires if im not mistaken, just takes like 2 minutes. good luck and have fun.
