6 bolt swap with 2g tranny
geno414
440
4
Jan 13, 2011
Milwaukee, Wisconsin
hey guys whats up so i blew my 2g turbo motor :banghead:
and i bought a 6 bolt short block well the guy who i bought it from had a fwd car and mine is a 1995 eagle talon tsi awd and his flywheel wont fit in my tranny ugh
so i dont know what to do because i need a smaller fly wheel but i can only find small 7 bolt ones i think im screwed can any one help ###
Pretty sure. FWD turbo flywheels are a bit larger in diameter than AWD flywheels.
The 6-bolt engines also used longer flywheel bolts. You might consider finding and using some of those (Mitsubishi part number MD040557).
allright thank you so much saved my summer
are you shure all i need is a awd fly wheel ? because i called summit and they dont know and i dont want to buy something and then it not work
I bought a 95 Talon TSI front wheel drive, with no motor but it has a 2g tranny Im guessing if I got a 6 bolt engine I need to swap the flywheels as well.
Your 7-bolt AWD flywheel fits the transmission, does it not?
The AWD flywheels use the same ring gear and are (as I've reasoned before in threads of old), therefore, the same diameter. No offense, but you aren't the first one to do this swap. A 7-bolt flywheel won't work for obvious reasons. You have a turbo 6-bolt FWD flywheel that doesn't fit, what other option are you left with? :p
You need an AWD 6-bolt flywheel. Period.
Yes. And look how convenient, geno414 has one! Fancy that! You should PM him to find out if he'll sell it. LOL
