6 bolt non turbo block question
lmarinukjr1980
Feb 13, 2009
philadelphia, Pennsylvania
i have a chance to get a 6 bolt nonturbo block it i want to do a rebuild the engine are the internals the same as the turbo? can i used turbo internals?
Is there any write ups or anything with pics? Is there a spot to screw them into? I found a site that sell them. i want to make sure im not getting into something to deep because i saved money on the bottum end.
1G DSM Oil Squirters
If its a non turbo block no you will need a machine shop to tap the oil line. Turbo blocks can just replace old ones with new ones.
A lot of guys run with the 6bolt NT blocks without oils quirters, and have no problems. Mavisky raced his 6bolt NT block without oil squirters for a long time.
You don't really need them.
  • Wanted 6 bolt NT water pipe
    • chrisman287
