1G 6 bolt Kiggly girdle/ARP main bolt question?
If they are in tolerance no line hone is required. But chances are they won't be. You'll need someone to check this, as you won't have the gauge for it. Typically when you upgrade the fasteners it squeezes the cap harder and reduces the vertical clearance.
To measure everything you need a round bar that’s perfectly straight and flat, a bore gauge, and a micrometer. The mic and bore gauge need .0001” resolution.
Damn near every time I’ve installed a girdle and studs, the size and roundness of the bores was in spec, as well as the alignment of the main bores.
Tagging onto this thread, are different ARP studs needed (longer) or are regular 6 bolt ARP studs fine?
