6 bolt awd flywheel?
Midshipman
May 3, 2012
Birmingham, Alabama
Ive found a ton of 6 bolt awd flywheels online. What is a good buy,brand and should i stay away from ebay? This is for a 98 gsx 6 bolt swap dd not a racecar by any means.
If you are interested I have a stock flywheel, clutch disk, pressure plate and clutch fork all with 350 miles on it. PM me if you want it. I went with the act 2600 and the act flywheel.
My fidanza weighs 7 lbs and it makes it easier to start smoothly on a hill cause the rpms are right there faster than the stock one but makes shifting diffrent due to fast rpm drop off. but is easy to get used to just got to pop the gas quick if shifting slowly.
