-6 AN Turbo Oil Feed line too big for B16G?
Turbo Shogun
260
Nov 23, 2003
Bolingbrook/Chi, Illinois
As the title states, I have a few lengths of -6 AN line laying around the house.
I ordered a 12mm banjo and a 3/8 to -6 AN 90* elbow for the oil filter housing. Is a -6 AN line too big to use as a turbo oil feed? Should I use a smaller -4 line instead?
It should be noted that I am also using the stock turbo oil return pipe and my balance shafts are removed, however, I did port the oil pressure relief valve to keep oil pressures under control.
Thanks for the input! :D
