57 trim tuning tips needed
sb7775
126
Apr 4, 2003
here is my set up
stock motor with crowler 414, new stlye lifters
evo 111 exhaust manifold
pte scm 34 (57 trim)
2g ported o2
full 3in exhaust
buscher front mount
sheet medal intake
AFPR set at 44psi
2g mas with all honey comes in place screw is backed out flush
egt and boost gauge with a logger(mmcd)
base timing set at 5 deg
255 with pte 680 cc
act 2600 with 95 street disc
i finally got the car together today and running. sounds great with the 414 and 3in exhaust. the only thing i did today is fix a water leak, set fuel pressure (44psi) and i pulled -7 from the low setting at 1000rpm so it would run a little better. idle is set at 800-850. i'm looking for someone with a similar set up or some tuning tips from experianced people only. i have searched and found mostly info on the 50 trim. any info will help thanx steve
