560cc injector seals
doobycareful
90
Oct 4, 2006
East Highland, Michigan
I just got my injectors and I see that there is 2 lower seals that are tight fit and hard and 2 of them are soft rubber and they loosly fit on the injectors. Can I use my seals from the old injectors or is this something I can buy from Napa or autozone? no mitsu dealer arround.
DO NOT reuse the lower injector seal. I would go to the dealer and get some new ones.
You can cheat and go to home depot race shop and get some 3/8th neoprean grommets those work fine.
GM makes the best injector cleaner part# 88861804
sorry thats the canadian part#, i don't know the american part number but gm calls it "upper engine and fuel injector cleaner" it'll run yah like 15$, but the stuff works great.
Did you get any injector seals to work with your 560 Evo injectors? I have the same injectors and I think I'm getting a bad boost leak.
Did the HD neoprene seals work?
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
