550cc injector rating
There is a lot of variables which will affect how much power you will be able to run on 550s, it all depends on your efficiency of your tune. If I were you, I'd be going 650s on a big 16g otherwise you will max your injectors way before the turbo! I'm on 650s now running 20psi and running about 70% Duty cycle however its a little rich now as Im running a bit too much timing. however even if you run 550s, make sure you control them with some sort of fuel control and definitely get a logger. If you do decide to get 650s or even 550s, hack your maf to lean it out a bit but you'll still need an a/f controller... you'll also want to retard the base timing a bit because I have found if trying to tune with an safc and much bigger injectors you will get way too much timing because the computer sees such little airflow.
Don't forget to account for the differences in fuel pressures that injectors are rated at. Most injectors are rated at 43 psi.
Do you have an AFPR?
Not yet. Im just getting a list of all the mods i want to get.
Injectors were the only thing i was still trying to figure out which i should get.
My goal is 300+whp unless i build it and in that case 450whp conservatively.
    • 4g63tv
    • 4g63tv
  • For sale 2g 99 2G parts
