50trim install banjo bolt elimination cant find a bolt short enough.
Lordpaxin
1,890
15
Apr 21, 2003
Jackson County, West Virginia
The guide specifies a 14x1.5x10 bolt.
The shortest i can find is a 45mm length.
im pretty sure im gonna have to cut it shorter, i doubt it will thread in. since the origional banjo bolt wont thread in flush.
talking about the banjo bolt on the block for the water return on a 2g.
I got a nut for it too, so when i cut it i can back it off and fix the end.
any ideas.
I would use a tap and dye set myself. If you can cut it pretty staright a tap and dye set will do the trick, making the bolt as good as new.
