50 trim or 60 trim?
ImportWarrior
308
Jan 18, 2004
Rochester, New York
i wnat to know what rpm average the 50 trim will spool at with a ported o2 and 3 inch exhaust? compared to a 16G or a 60 trim with the same setup?
:dsm:
i want to get a 50 trim and dont want to wait till 4xxx plus rpm to spool!
if a 60 trim is not much slower than a 50 id go the 60
thanks
Spool up is not the only thing you shoudl be looking at when buying a turbo. You need to decide you power goal and what type of gas you plan on running among other things. The 50 trim will make more power on pump gas than almost any other turbo on the 4g63 so keep that in mind. I wont go over a 50 trim for that reason unless I decide to make the car more race than street.
Also if you are that worried about spool up then a turbo of that size may not be for you. The only way to get a big turbo to spool faster is to go with a ball bearing center section and that adds a good deal to the price.
Let us know your goals and we can help you better select a turbo.
Michael
:talon: :laser:
thanks for the replies!
my goal seems to be more aimed at street. i might look more towards a 18G TD06.
thanks for your time!!!
