5 speed swap parts list
_97tsiawd_
149
Aug 6, 2007
camas, Washington
I have a 97 tsi awd and am thinking of swaping out my auto tranny and going with the 5spd. I cant seem to find a parts list anywhere so i was hoping someone would have it.
Thanks :talon:
Looks like you just didnt try hard enough...
*5sp ECU
*Wiring Harness
*Transmission
*Starter Plate
*Starter
*Axles
*Slave Cylinder
*Clutch pedal assembly
few other parts but those are the basics...
ECU and harness? What?
This is what you need:
*Transmission
*Starter Plate
*Starter
*Axles
*Slave Cylinder
*master cylinder
*manual brake pedal
*clutch assembly
*flywheel
*shifter cables
*shifter assembly
*motor mount
*Transmission
*Starter Plate
*Starter
*Axles
*Slave Cylinder
*master cylinder
*manual brake pedal
*clutch assembly
*flywheel
*shifter cables
*shifter assembly
*motor mount
I can see the harness. Not the ECU, though. The auto harness has a bunch of extra pigtails for the auto. It would be so messy with the auto harness in a manual car.
Either stick with the auto or sell it and pick up a 5spd. I mean in the end the total is not worth it. Unless you want to fetch up some loot and a load of hours.
