4G64 Crank
talont3t4
416
Feb 9, 2003
Edmonton, AB, Canada
Does anyone have the Mitsubishi Part # for the 6 bolt 4G64 crank. Thanks Ron
peregrine said:
But aren't they the same, or is that why you are laughing. The 4G64 is a direct replacement for the G4CS and probably made in the same factory (possibly the same line). The only issue I could think of is that a G4CS crank for an automatic transmition has some kind of tab that can be removed for use with the 63's manual transmission.
MD080691 is the part number for a 6 bolt 2.4 crank! Not available from mitsu anymore :(
You can use the 2.4 crank out of a old sonata also! You will pay a premium for a new mitsu crank if you can find one!
Actually the specs are different the bearings are NOT the same I have tried to use both :)
