4g64/4g63 head gasket?
lauj2gdsm
326
Jan 16, 2005
stockton, California
the only head gasket im able to get is the felpro sohc head gasket.. every thing lines up to the block and bore except the 5 extra plugged holes so it had some open spot on the gasket for the 5 oem 4g64 drain holes. can this head gasket be used?
anybody anyone?? i have the sohc gasket now.
ok i took a caliper guage and measure the felpro 4g63 composite and felpro sohc 4g64 composite. they measure the about same 87.45mm bore. so for future search the felpro 4g63 will fit many over bore sizes including 4g64 swaps.
A little late now, but with a Mitsu composite 4g63 gasket and 86mm bore I still had about 1.5-2mm between the fire ring and cylinders. Thanks for updating with the answer though, that's good info to have.
