420A 4g63t engine & transmission swap
99GS4G63Swap
Jun 16, 2021
Seattle, Washington
Hello looking to swap from a 420a into a 4g63t with trans. Took a brief look at transmissions and was only able to find 2 2g dsm trans for 10k a piece. Is there a suitable aftermarket transmission that will pair well?
The engine that came in your non turbo car the 420a engine sits on the passenger side of the car whereas the turbo engine the 4g63t resides on the driver side of the car, while its not impossible to put the 4g63t into a non turbo 420a chassis, it IS a lot of work and generally left to those with welding and fabrication skills, paying someone to have it done would not be cheap, if you know someone that can do it with you, or if the car is sentimental to you then by all means go for it, the motor mounts and transmission mounts will have to have the spot welds drilled out, the mounts pried off and then re-welded to the opposite side of the car, in addition everything else will have to be taken from a turbo model and transferred to the non turbo model such as the wiring harness, fuel delivery components etc, there are write ups on how it is done if you search for them.
Thank you. I’ll definitely look into it. Wasn’t aware the mounts were on opposite sides of the car. I mean gst/x aren’t cheap either. I’ll see what I can come up with thank you!
  • For sale 1g 1G AWD Engine Side Splash Shield
    1G AWD Engine Side Splash Shields $55 a piece + shipping & paypal fees* I don’t have any...
  • For sale 2g 2G OEM Cargo Net
    2G OEM Cargo Net $40 + shipping & paypal feesYou must be registered to see element.
  • For sale 2g 2G Auto Shifter Cable ( GSX/GST )
    2G Auto Shifter Cable $45 + shipping & paypal fees* GSX/GSTYou must be registered to see...
  • For sale 2g 2G Auto Shifter Base
    2G Auto Shifter Base $40 + shipping & paypal feesYou must be registered to see element.
  • For sale 1g Mishimoto radiator
    Mishimoto X-Line Aluminum Radiator | 1990-1994 1G DSM (MMRAD-ECL-90X)
    • william
