450lph fuel pump, rewire needed?
Absolutely, that pump draws a lot of amps. You'd be fine to test for leaks and drive around but don't expect it to hold up when you start asking for more pressure out of it.
I turned the key and I didn’t hear any fuel pump noise, which is setting me off. The battery was also pretty dead which could be it but I’ll see soon.
I figure I’ll just do the rewire today. I’m looking into dummy threads about requiring and it talks about PIN 86 of this relay, what relay is it? How do I ask a parts store if they have this type of relay in-stock?
You can use a SPST or SPDT 30 amp Bosch relay for a pump rewire. Both should be available at just about any auto parts stores, or you can order a bunch online for about $1 per relay vs $15 for one.
85 and 86 are the coil terminals, you hook the stock turn on signal to one side and ground the other. Pins 87 and 30 are your high current connections once the coil is activated, allowing straight battery power to go through to the pump. 87a (center pin) in an SPDT relay isn't used on this application, and is common (connected) to pin 30 when the coil is de-energized/off.
So 10-8awg fused battery power to 87, 10-8awg from 30 to fuel pump. Stock pump turn on wire to 85, ground to 86.
  • For sale 1g 1G AWD Fuel Filler Neck
    1G AWD Fuel Filler Neck $75 + shipping & paypal fees* I would replace the rubber elbowYou...
  • For sale 1g 1G 4 Bolt LSD Rear Axle Set
    1G 4 Bolt LSD Axle Set $120 + shipping & paypal feesYou must be registered to see...
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
  • For sale 4G63 6 Bolt ARP Head Studs
    ARP 6 Bolt ARP Head Studs $65 + shipping & paypal fees* these have been torqued onceYou must...
