kraka
- 821
- 4
- Dec 31, 2003
Chicago/Iowa City,
Illinois
WTF?
So Im out logging when Im driving home, just cruising on a normal road...I do a small 2nd and 3rd gear pull....Yup, 0-2 counts of knock at most maybe, Im doing pretty good...
Then, I decide for the fun of it I should try logging a normal traffic light to traffic light style log....So, I start to log, put the car into 1st, and slowly just cruise thru first gear....As soon as my foot touched the gas and released the clutch, I hear *BEEP BEEP BEEEEEEEEEEEPPPPPPP* from my logger....I set an alarm for large counts of knock, and to my suprise, I look down while just cruising in 1st gear slowly and im getting 20-43 counts of knock!!
WTF Im thinking...So to see whats up, I quickly shift into 2nd and go WOT....No knock....Weird....Next stoplight I stay in neutral....At 750rpm, no knock....Ok, so I give it a small rev, going about 20-40% throttle and only to like 4500rpm....*BEEEEEEP BEEEEEP* ....up, 10-30 counts of knock on a large rev....As I take off slowly, limping the car in 1st gear, the Knock alarm continues to go off until I've started to gain momentum in a higher gear...
Whats going on? Possible solutions:
- KNock sensor is bad --- But wouldn't this make knock appear at WOT also?
- Fuel filter clogged --- again, I only get major knock in 1st w/ light throttle
- Boost leak --- I already get bad vaccuum, so there is a leak, but that bad?
- Phantom knock-- More vibration in 1st then at WOT in 3rd? No way....
Finally, I wanna add that I called AMS, and he agreed with me thinking it was Phantom knock....The guy said it shouldnt make a difference, and I should just ignore it, its not harming my performance....Im still worried tho, because I know it pulls tons of timing, and it doesnt feel different when I drive it like that, but why would I just ignore it?
Idea's comments?
---Walbro 190, SAFC, 560's installing tomorrow
Idea's comments?
