420a Will not turn over
Chrispy0530
913
26
Aug 7, 2008
Miami, Florida
Tried searching a bit, but couldn't find a thread that had a solution.
Basically what's happening with my Talon ESi is when left alone for a while, it does not start/turn over at all. But if I push start it ( it's a 5 speed ), it fires up fine, and will fire right up if I turn it off and back on shortly. It stops turning over if I leave it alone for more then 10-15 min.
Things that have been tested
-Starter is OK
-Alternator is charging, and battery is good
-Fuel pump is priming when turning on key
Car refuses to turn over, and pretty much does nothing. Tried bypassing the clutch safety, and still same result.
Any ideas?
i wonder if the starter relay is messed up. check your volts on the starter it should be around 11v and make sure you got power to the asd relay on the firewall. theres not corrosion on the terminals right?
