Resolved 420A Oil pump bolt size needed
99-420a
3
Jun 30, 2018
Newark, Ohio
I have been rebuilding my 420A and I believe my oil pump bolts got knocked into a box that got thrown out.
I need to know the bolt specs for the oil pump to block and the oil pickup tube bolt.
I have searched and I believe the oil pump to block is m8x1.25x25mm if someone can verify that would be great.
Since I got no answers I went and bought some 10.9 m8 flange bolts of all different sizes. For future reference if anyone needs the info this is what I used.
Oil pickup tube bolt m8x1.25x25mm
Oil pump to block 5x m8x1.25x25mm
2x m8x1.25x50 for longer oil pump to block.
Word of caution I may not have correct length of the longer ones. I am not 100% positive those are actually the size I ended up using since I had 3 sizes in the same bag. May want to grab the next size up and down from that if in doubt.
