420a no voltage from ecu to cam position sensor
tryingtofixthis
36
Mar 16, 2014
columbus, Ohio
No volts directly off ecu with key in on position. High pitched noise from ecu. Bad pcm/ecu?
Asd has power
Crank sensor has power
Coil has some power low volts.
Wrong cam sensor was used on circuit at on point. Wires d on that pigtails and probably grounded out more than once.
