2G 420A No heating no stereo no power locks
KriskoDSM
May 8, 2023
Troyan, Europe
95 GS. First of all please believe me I spent hours scrolling through threads in different forums and I couldn’t find anyone with the same problem. So, as I was driving the other day my stereo died, my heating fans stopped working and after parking I found that the rear window defogger, interior lights (under the dash and on the roof) and power locks are not working either. Other than that everything from headlights to gauge lights works fine. I’ve checked the fuses and relays in the engine bay fuse box and they all seem to be working fine. Do note that the first time this happened everything turned back on out of the blue and then at some point died again. It can get down to -5°C in my area and that car is my daily so the quicker I can get this sorted the better.
Should trace and check all fuses/connections/contacts/wirings that are coming from the fusible link #2 60A yellow fuse.
I will do that and update. Thank you!
Was it an open circuit inside the fuse or is it just melted?
I’m really not good with electronics but the fuse looked intact from a first glance, however i had a hard time getting it out of the port because it was indeed melted. Hopefully i can find a new fuse after the holidays and pray that’s where the problem was
