$400 upgrade
1991_talon
156
Sep 25, 2010
Connersville, Indiana
Hey guys I have about 400 bucks from my college loans to spend on something to improve my cars perfomance here is a list of my current mods. Please leave suggestions, thanks.
HEAD: crower 272 cams
crower springs and retainers
Arp head studs
Revised lifters
Bottom End:Arias pistons
Crower I beam rods
Clevite 77 bearings
balance shaft eliminator kit
new water pump
new oil pump
Power interprise timing belt
OEM tensionor
BOLT ons:
3 inch exhaust
Bullseye 60-1 turbo, perfect
SBR exhaust manifold
Tial 38mm watsegate
SBR FMIC
2gmaf
Dejon intake
Aem wideband
Aem truboost
DSM link
SUSPENSION:
Megan racing lowering springs 2"drop
Brand new struts
DRIVETRAIN:
Jacks tranny double synchros and other mods
Driveshaft shop axles
Fidanza 4.3 clutch kit
Fidanza flywheel
Exterior: MSW type 11 17" rims
BRAND NEW paint JOB
The engine has roughly 15k on the rebuild and the stage four clutch has about 6k miles on the kit and flywheel. The car runs 11.90 Id like to reach 11.50 eventually. 550 injectors sorry forgot to list.
only 550 injectors? id check if your maxing them out. if you are maybe switch to e85 and tune it and you can squeeze more power out
Edit:
Obviously you would need to buy bigger injectors and maybe a bigger pump (i didn't see one listed)
Get a wally 255 and a AFPR. Then up your pressure and start running some more boost and get those injectors running. No reason you cant hit lower 11's if you up the boost. Oh get some bigger injectors as well if possible.
Some used 750s = $150, used AFPR = $150, Used wally = $100
Theres $400 bucks
Also do you have any other suggestions? Id like my turbo to spool a little faster.
Theres $400 bucks
I have an AEM True boost gauge along with a fuel to air ratio gauge. Is it still nessary to get a AFPR?
LOL yes sir stroking a block aint cheap.
I can regulate my fuel pressure through dsm link right? Is so I just need injectors and possibly a wally.
I got 750 and I will get 750 more next semester. I will aquire roughly 250k in 2 yrs so not worry about loans.
A AFPR is a Adjustable Fuel Pressure Regulator. You have a boost controller and a wideband. Every car needs these to tune properly. And to increase your boost and fuel a significant amount to make real power, yes you will need a AFPR.
This allows you to bring your stock fuel pressure from 38psi up to say 58psi. This would theoretically let you run 20psi completely safe and gives you A LOT of room for more boost, instead of squeezing 25 out of your car now.
Edit: Thanks for the replies guys I think I'm going to give J racing a call and see what they can do.
Ok thank you sorry for the noob question, but how much do u think J racing would charge to tune put in a AFPR injectors and a 255 pump? Your rough estimate.
Your sure DSM link cant turn up my fuel pressure? Im new to the DSM world sorry guys.
Yes I did but I got a hell of a deal on it. I know a little about mechanics but ive never been mechanicly inclined. The most ive done is swap an 89 302 into a 94 mustang. No aftermarket work.
I found a set of 8 EB bosch injectors I think I've finally made my decision thanks guys.
i dont see this going well, but im with the other guys, you need more fuel, but id do alot of reading first. sounds like you have some catching up to do
I do have 850 injectors and wolboro 255 high pressure pump along with afpr on the car check this morning.
j racing is about an hour and a half away i plan on having them tune it and saving the money I have left.
Save the $400 for next semester.
I'm with Wes, been through college, keep your loans to a minimum. Cars will come and go. If you take out $400 extra a semester, that's more than $3,200 over the path of 4 years with interest. That's my 2 psi.
Listen to these guys. Been there, done that, and was completely broke because of it.
Im just gonna have it dyno tuned I have pretty much all the mods i can do done LOL. Ill spend the rest on books for next semester.
