3rd Time is a Charm
airmail96
1,077
3
Mar 28, 2005
Virginia Beach, Virginia
Welp, I am back in the game and this time with an awd, this makes my third dsm. I say third time is a charm because my first 2 dsms were lost to a series of unfortunate events (wrecks) so I feel that if I wreck this one I'm not meant to have a dsm LOL. Anyway a little about the car it is a 93 Tsi AWD, running a 2g Mas, 550 cc injectors, hard upper and lower intercooler pipes, 2.5in exhaust, knock off bov valve vented, forge MBC, Buschur Stage 1 block with 60k, walbro 255, afpr and a small 16g I think.
Car is going to need a little work, there is a little oil leak on hte left side of the motor, but I think it is coming from the oil pressure guage sending unit, car is popping out of reverse, transfer case is leaking a little, needs and alignment, a new shift cable, side panel on the door glued back on, window switches, and a head liner.
My plans are to fix the little issues that I have, such as replacing the tranny, getting DS-Map installed on it and getting the car tuned, then getting the required bolt ons (FMIC, 1150s, upgraded fuel lines, dual pump hanger maybe(thinking about running e 85) I need so that I can mount on my He351VGT that I have sitting around in my closet.
All in all not bad for a $2100 dollars. Anyway just thought I would post up my new DD/Project.:rocks: Glad to be back.
Welcome back and good luck with your new car. :thumb: :talon:
WOW!! where im from this would be a major steal the car looks great for 2100. this is also my third dsm if you consider a summit dsm. wrecked my 95 gs and my 98 gst was kind of stolen :(
Lol, I'll admit I was at fault in the wrecks, do to not paying attention in my first one, amazing what can happen in a split second, and the second was due to bad tires and improper driving in the elements (Hydroplanned). My driving has improved and I have become a lot more meticulous when I do work on my car, so hopefully all goes well.
Nice 1g man if you wreck this on dibs on hubs and rear end ;) haha good luck man
I miss my 92 AWD. Put some 97 TSi AWD wheels on it. They look so sick on the 1Gb. Looks like you found a great project.
knochgoon24;bt5315 said:
Are you just going to use an internal WG actuator on the VGT?
Yes I am, actually bought everything but the turbo from danzy250f
set up
Dyno
Thank you for all the compliments, I def. like the look of the car with the bronze wheels on it, but thank you for the suggestion on the 2g talon wheels.
what kind of wheels are on it? they look like enkei rpf1's but i doubt that for 2100 for the whole car LOL. ive been looking for a knock off set of them
Very nice buy man i like the wheels on it. Good Luck with the car and keep everyone posted on the progress!
So upon further research I have come to the conclusion that the rims are motegis, the have been spray painted over I think since some of it is chipping off, i think they are Motegi MR105s.
