Resolved 3g Rear Knuckle on a 2g
the 3g seems to have the same setup as the 2g. some of the parts have been changed from stamped steel (2g) to a tubular design. there is a small difference in the upper arm specs. As far as i know the rear brake setup is the same also. the 2000 3g knuckle has the same part number as a 2g. 2001+ has a few different part numbers but im not sure what is different about them.
.....................................2g...........................................................................................................................................3g.......................................................
possibly. the part numbers are different. the difference may only be the mounting brackets. I have a 3g in the driveway so if i have time i will check tomorrow.
i noticed that
the models with the 2.4L engine (RS, GS) only come with drum brakes in the rear.
the 3.0L V6 equipped car have the exact same rear disc brakes as a 2g.
i noticed that
Thank you! I'm just making sure before I visit the junkyard. If they're both the same style for disc, I'm guessing I can also do the Outlander BBK on the 3g knuckle.
Some of the Galant suspension components can be used as well. Ive got rear upper & lower galant control arms on mine.
